Migrated to V5 but get some strange issues with customer numbers. I have four companies in my Pro plan, one is ok. That company I can sort on customer number. I got one company where the customer numbers are a bit weird, like e.g. 3.0624000000368e16. There sorting doesn’t work if I want the latest customer. It is sorted like 3.0624000000368e16, 4, 3, 2, 1.
And another company where in customer panel I get 99, 98, 97, but there are more than 99 customer. So I can’t get to view the latest customers easily.
I guess it has to do with how the customer numbers get migrated. In the company where the sort fails the numbers are with and without preceding zero’s. So I have 00, 01, 02…09, but then it goes to 10, 11 … When sorting for higest number I get 99 on top while there are more than 99 customers…
Thanks for the details. I think this may be from lowering the zero padding (01 vs 0001). If you increase the padding it should correct it but we’ll also look into sorting correctly in this case.
