ivanye
July 25, 2020, 7:52pm
1
1, Can`t email invoice to clients, even thought it shows SENT, but clients never received.
2, But we can check the invoice via $URL/client/invoices/ , can see invoices there, but pdf files 404 ERROR, which can show on our backend.
3, Can`t set Payment Gateway Fees like PayPal Fee, Once set and saved, it will be blank again automatically.
ivanye
July 26, 2020, 6:43am
3
1, Yes. I installed both V4 and V5, use same email settings. It works charm in V4, but error on V5.
2, Did, nothing changed. Is there any other command i need to do after changing in .env file?
3, I can see the pdf invoice in my server, but Client Side shows 404 ERROR. Also the pdf won`t refresh when i edit the invoice. I have to delete the pdf invoice, then it can generate a new one. Is that the cache doing the trick? How to clean the cache.
4, And the logo on Client sides also 404, google chrome says it is
/app/public/9QMV7Cr4AZ9ASlCQX7KkCv2xZwrhK31fL6lhTSM9PNDPWph0l6huUzHDHSFAdbhl/zXjYJ5Sz8uQzNN4Tq9uRaWGzAHCJXgsofAlAKeoR.png
ivanye
July 26, 2020, 8:19am
4
And there is $viewlink in the Email Generated Automatically
July 26, 2020, 9:18am
5
Thanks for screenshots! I’ve asked Dave and/or Ben to jump in to help.
July 26, 2020, 1:24pm
6
For #2 it may help to run php artisan config:clear
ivanye
July 27, 2020, 4:57am
7
Still Nothing Changed.
I am wondering, since it cant generate the $viewlink, is that possible can
t gather the Client`s Emaill Address neither?
That is why Clients never receive it. And that is also failed on your v5 Demo.
For can`t show pdf invoice on Client Portal, is there any tools i missed or need to reinstall?
July 27, 2020, 6:11am
8
I shared this on Slack, here’s some info:
"This is most likely wrong Nginx rewrite configuration. I’ve just changed my app_url to be the wrong one (the one that does not exists) and it still displays the assets correctly.
/app/public/9QMV7Cr4AZ9ASlCQX7KkCv2xZwrhK31fL6lhTSM9PNDPWph0l6huUzHDHSFAdbhl/zXjYJ5Sz8uQzNN4Tq9uRaWGzAHCJXgsofAlAKeoR.png"
If paths are rewrited correctly url to images should be my-awesome-website.com/images/invoiceninja-white-logo.png."
ivanye
July 27, 2020, 9:04am
9
Hi hillel,
Logo problem solved!
Here is my Nginx config, could you kindly help me locate the problems?
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name invoice.xxx.com;
root /home/user/invoiceninja/public;
client_max_body_size 10M;
gzip on;
gzip_types application/javascript application/x-javascript text/javascript text/plain application/xml application/json;
gzip_proxied no-cache no-store private expired auth;
gzip_min_length 1000;
#ssl
ssl_certificate /etc/ssl/invoice.xxx.com/fullchain.pem;
ssl_certificate_key /etc/ssl/invoice.xxx.com/privkey.pem;
ssl_protocols TLSv1.1 TLSv1.2 TLSv1.3;
ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:HIGH:!aNULL:!MD5:!RC4:!DHE;
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 10m;
error_page 497 https://$host$request_uri;
charset utf-8;
location / {
try_files $uri $uri/ =404;
if (!-e $request_filename) {
location ~ \.php$ {
include snippets/fastcgi-php.conf;
fastcgi_pass unix:/run/php/php7.3-fpm.sock;
#fastcgi_index index.php;
include fastcgi_params;
fastcgi_intercept_errors off;
fastcgi_buffer_size 16k;
fastcgi_buffers 4 16k;
location ~ /\.ht {
deny all;
location = /robots.txt { access_log off; log_not_found off; }
access_log /var/log/nginx/ninja.access.log;
error_log /var/log/nginx/ninja.error.log;
sendfile off;
server {
listen 80;
add_header Strict-Transport-Security max-age=2592000;
rewrite ^ https://$server_name$request_uri? permanent;
July 27, 2020, 12:39pm
10
Sorry, I’m not sure.
You may want to test with the sample Nginx config provided here:
https://invoiceninja.github.io/selfhost.html#installing-invoice-ninja
NZNinja
November 18, 2021, 10:34am
11
hillel:
To fix this usually you just have to re-upload the logo file.
