Howdy all,
I am trying upgrade from v4.5.50 to v5.3.84-C78
I don’t see any other errors except:
Trying to get property ‘client_id’ of non-object
I have no issues with v4. I have been using it since v3 and have upgraded it many times. I upgraded from v4.5.19 before the upgrade. Version 5 was a new install and I don’t seem to have any issues with it.
I have never purged my system in the past as far as I remember. What can I do to get the migration to work. I only see one other case where someone had the same issue: https://github.com/invoiceninja/invoiceninja/issues/4989 , but it seems it was a bug and a patch was issued. Am I dealing with another bug that was introduced with these new versions?
The error indicates it is trying to access a property which doesn’t exist. Without inspecting the data closely, it’ll be impossible to work out the issue.
If you want to DM the file located in (storage/migrations/) we can take a look.
There are no files in the storage/migration folder. I have never seen it create any files. I don’t think it even gets to that point. It stops almost immediately with the error.
@david
I don’t have a public/storage/migrations folder on v4. I don’t even have public/storage on v4. I have it on v5. I have nothing in the storage/migrations folder on v4. I don’t see any files being built. It seems to just say getting and then exits with the error.
@david
Yes, I am very sure. I checked both v4 and v5 and listed above what I saw. Is there a deeper debug mode or something we can run during the migration to see what is going on?
@david
I just did a new install of v4.5.50 and installed just the database to verify nothing was wrong with the system. Of course v4.5.50 works just fine. I don’t understand what is wrong with the database that it doesn’t like. I have migrated this database from 2018 and has been upgraded from v3 to v4 and now trying upgrade from v5. I have had whitelabel since 2018 (might have been earlier). I might have even been around since v2. I have been using Invoice Ninja for a very long time.
The only migration.zip file is on v5 and in: /usr/share/nginx/invoiceninja/tests/Unit/Migration/migration.zip
This looks like a test migration file, it is not my data. As I said after I select a company to migration It returns immediately with the error: Trying to get property ‘client_id’ of non-object
So I don’t think it ever even gets to the point of building anything.
@david
I have no errors in the logs. I don’t know what line number it errors on. It just stops at the last line in the laravel-info.log. I checked again and no zip file was created on either v4 or v5.
I only have this in: laravel-info.log
[2022-05-09T23:11:03.177096+00:00] production.INFO: get get company gateways => 2 [] []
[2022-05-09T23:11:03.177195+00:00] production.INFO: translating gateway ID = 23 [] []
[2022-05-09T23:11:03.208642+00:00] production.INFO: translating gateway ID = 23 [] []
[2022-05-09T23:11:03.208901+00:00] production.INFO: get transform fees and limits [] []
[2022-05-09T23:11:03.215644+00:00] production.INFO: get transform fees and limits [] []
[2022-05-09T23:11:03.217088+00:00] production.INFO: translating gateway ID = 17 [] []
[2022-05-09T23:11:03.222411+00:00] production.INFO: translating gateway ID = 17 [] []
[2022-05-09T23:11:03.222643+00:00] production.INFO: get transform fees and limits [] []
[2022-05-09T23:11:03.240744+00:00] production.INFO: get client gateway tokens => 28 [] []
[2022-05-09T23:11:03.263526+00:00] production.INFO: Trying to get property ‘client_id’ of non-object [] []
