I’ve searched and searched and couldn’t find similar issues. Here is my current situation:
Self Hosted v5.5.20
Ubuntu 18.04 VPS on Digital Ocean
I have been using the hostedpdf for some time but decided to revisit getting snappdf to work today. Enabled debugging and the endpoint /api/v1/live_preview?entity=invoice returns the output below.
I discovered snappdf was not working from the CLI when trying vendor/bin/snappdf convert --html "<h1>Hello world</h1>"
test.pdf from root of invoiceninja5
Installed additional dependencies and “snappdf convert” is now working and generating PDF as expected however the live_preview endpoint is still returning the response below.
Any suggestions would be greatly appreciated.
"message": "Call to undefined function Symfony\\Component\\Process\\proc_close()",
"exception": "Error",
"file": "/var/www/invoice5/vendor/symfony/process/Process.php",
"line": 1388,
"trace": [
"line": 1299,
"function": "close",
"class": "Symfony\\Component\\Process\\Process",
"type": "->"
"line": 836,
"function": "updateStatus",
"type": "->"
"line": 428,
"function": "isRunning",
"type": "->"
"line": 249,
"function": "wait",
"type": "->"
"file": "/var/www/invoice5/vendor/beganovich/snappdf/src/Snappdf.php",
"line": 229,
"function": "run",
"type": "->"
"file": "/var/www/invoice5/app/Utils/Traits/Pdf/PdfMaker.php",
"line": 44,
"function": "generate",
"class": "Beganovich\\Snappdf\\Snappdf",
"type": "->"
"file": "/var/www/invoice5/app/Jobs/Util/PreviewPdf.php",
"line": 50,
"function": "makePdf",
"class": "App\\Jobs\\Util\\PreviewPdf",
"type": "->"
"file": "/var/www/invoice5/app/Http/Controllers/PreviewController.php",
"line": 304,
"function": "handle",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Routing/Controller.php",
"line": 54,
"function": "live",
"class": "App\\Http\\Controllers\\PreviewController",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php",
"line": 45,
"function": "callAction",
"class": "Illuminate\\Routing\\Controller",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Routing/Route.php",
"line": 261,
"function": "dispatch",
"class": "Illuminate\\Routing\\ControllerDispatcher",
"type": "->"
"line": 204,
"function": "runController",
"class": "Illuminate\\Routing\\Route",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Routing/Router.php",
"line": 725,
"function": "run",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php",
"line": 141,
"function": "Illuminate\\Routing\\{closure}",
"class": "Illuminate\\Routing\\Router",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php",
"line": 126,
"function": "Illuminate\\Pipeline\\{closure}",
"class": "Illuminate\\Pipeline\\Pipeline",
"type": "->"
"line": 62,
"function": "handleRequest",
"class": "Illuminate\\Routing\\Middleware\\ThrottleRequests",
"type": "->"
"line": 180,
"type": "->"
"file": "/var/www/invoice5/app/Http/Middleware/QueryLogging.php",
"line": 39,
"type": "->"
"line": 180,
"class": "App\\Http\\Middleware\\QueryLogging",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php",
"line": 50,
"type": "->"
"line": 180,
"class": "Illuminate\\Routing\\Middleware\\SubstituteBindings",
"type": "->"
"file": "/var/www/invoice5/app/Http/Middleware/Locale.php",
"line": 46,
"type": "->"
"line": 180,
"class": "App\\Http\\Middleware\\Locale",
"type": "->"
"file": "/var/www/invoice5/app/Http/Middleware/TokenAuth.php",
"line": 96,
"type": "->"
"line": 180,
"class": "App\\Http\\Middleware\\TokenAuth",
"type": "->"
"file": "/var/www/invoice5/app/Http/Middleware/SetDb.php",
"line": 40,
"type": "->"
"line": 180,
"class": "App\\Http\\Middleware\\SetDb",
"type": "->"
"line": 116,
"type": "->"
"line": 726,
"function": "then",
"type": "->"
"line": 703,
"function": "runRouteWithinStack",
"type": "->"
"line": 667,
"function": "runRoute",
"type": "->"
"line": 656,
"function": "dispatchToRoute",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php",
"line": 167,
"type": "->"
"line": 141,
"function": "Illuminate\\Foundation\\Http\\{closure}",
"class": "Illuminate\\Foundation\\Http\\Kernel",
"type": "->"
"file": "/var/www/invoice5/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php",
"line": 45,
"type": "->"
"line": 180,
"class": "Sentry\\Laravel\\Http\\SetRequestIpMiddleware",
"type": "->"
"file": "/var/www/invoice5/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php",
"line": 42,
"type": "->"
"line": 180,
"class": "Sentry\\Laravel\\Http\\SetRequestMiddleware",
"type": "->"
"file": "/var/www/invoice5/vendor/livewire/livewire/src/DisableBrowserCache.php",
"line": 19,
"type": "->"
"line": 180,
"class": "Livewire\\DisableBrowserCache",
"type": "->"
"file": "/var/www/invoice5/vendor/beyondcode/laravel-query-detector/src/QueryDetectorMiddleware.php",
"line": 27,
"type": "->"
"line": 180,
"class": "BeyondCode\\QueryDetector\\QueryDetectorMiddleware",
"type": "->"
"file": "/var/www/invoice5/vendor/barryvdh/laravel-debugbar/src/Middleware/InjectDebugbar.php",
"line": 66,
"type": "->"
"line": 180,
"class": "Barryvdh\\Debugbar\\Middleware\\InjectDebugbar",
"type": "->"
"file": "/var/www/invoice5/app/Http/Middleware/Cors.php",
"line": 25,
"type": "->"
"line": 180,
"class": "App\\Http\\Middleware\\Cors",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php",
"line": 39,
"type": "->"
"line": 180,
"class": "Illuminate\\Http\\Middleware\\TrustProxies",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php",
"line": 21,
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php",
"line": 31,
"class": "Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest",
"type": "->"
"line": 180,
"class": "Illuminate\\Foundation\\Http\\Middleware\\ConvertEmptyStringsToNull",
"type": "->"
"line": 21,
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php",
"line": 40,
"type": "->"
"line": 180,
"class": "Illuminate\\Foundation\\Http\\Middleware\\TrimStrings",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php",
"line": 27,
"type": "->"
"line": 180,
"class": "Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize",
"type": "->"
"file": "/var/www/invoice5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php",
"line": 86,
"type": "->"
"line": 180,
"class": "Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMaintenance",
"type": "->"
"line": 116,
"type": "->"
"line": 142,
"function": "then",
"type": "->"
"line": 111,
"function": "sendRequestThroughRouter",
"type": "->"
"file": "/var/www/invoice5/public/index.php",
"line": 57,
"type": "->"
