I apologies, I know this has been talked about many times and I have researched pass post with no luck. For some reason email function stopped working when I try to send out an invoice. I have confirmed the .env and all values are correct. Text below have been cleansed.
Thanks for this. Everything seems to be set correctly and set to SMTP. The weird part is it was working beforehand.
The laravel shows no errors, and the System log does not even indicate an email tried to be sent out. I do have the QUEUE_CONNECTION=database set; I am just unsure how to check the database to see if emails are being queued on a cpanel shared hosting platform.
When I do send a test invoice via email, it tells me at the bottom of the page after I click send email, “Successfully queued quote to be sent”. So its safe to say its being queued? If so, why now, and is there a way to fix this?
As a first step I suggest changing QUEUE_CONNECTION to sync. You may need to load /update?secret= or run php artisan optimize to recache the config. You can check the change was applied using the health check option in the about dialog in the app.
@hillel, that was it sir. I changed QUEUE_CONNECTION to sync and performed the /update secret and it did the trick. I had to resend the queued quotes but I am happy to report it worked out.
@ShaferRV as Hillel mentioned, if your logs are cleaned and if your SMTP info is setup correctly than the suggestion that @hillel did the trick.
