However, now if either terms or publuc notes is empty, I get the variable ‘$publicNotes’ or ‘$terms’ printed on the invoice.
I can see it looks like there’s been a change with these variables, but could do with a pointer as to how I get them to not print on the invoice when they are empty.
Thanks. For a quick fix, if possible, using your new $notesAndTerms variable, how would I get the notes and terms to display without the $subtotals bit?:
Yes. It seems it needs specific layout (see below). Will the next release go back to allowing me to use those individual variables Hillel? One template separates them you see:
Just to confirm, this issue (empty variables having their variable names displayed on PDF’s) is addressed as Hillel described, in the newly released version 4.4.4
