/settings/data_visualizations just shows an empty window
I’m assuming you’re self hosting the latest version of the app.
Yes it’s self hosted. And there are no warnings or errors in the console
I’m not sure, I can’t replicate the problem.
It could be something specific to your data. If you want you can view the page source and email the line following ‘// store data as JSON’ to contact@invoiceninja.com.
Was correct on 4.3.1 and again the problem is there in 4.4.0.
I am using Spanish localization.
Regards.
Try applying this patch to your code:
https://github.com/invoiceninja/invoiceninja/commit/422d5c5cdc7e735abf8cfd1f5a35e63be51cfd99
Thanks, now is working well.
