I setup Invoice ninja, but in configuration form I didn’t check HTTPS.
How can I change it?
thanks you.
thanks you.
You can manually edit the .env file and then run php artisan optimize
I already did it, I changed http://url to https://url at .env file.
It was working well, after setting up let’s encrypt cert, that force my website to use https , and then it stopped to work pdf previews.
PlatfomException(error Promise was rejected with a value ‘undefined’., null,null)
any idea?
Does the PDF display correctly in the client portal?
Im not using client portal yet, I just use administrative access (full access)
But it was working after migrate to https
I suggest checking if the PDF loads correctly in the client portal.
But I dont know how to access to client portal, it’s enabled.
There are “Client Portal” actions available for clients and invoices
