I have installed two separate instances of invoice ninja V 5.1.6.1, setup the crons, and proceeded to add the clients yesterday everything was working fine. This morning I cannot login to both instances. All I get is a 500:Server Error at the login screen.
Nginx is not throwing any errors in the error logs, but the access logs confirm the 500 error :
“POST /api/v1/login?first_load=true&include_static=true HTTP/1.1” 500 44 “https://redacted/” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36 Edg/90.0.818.56”
The crons seem to be working :
Running scheduled command: ‘/usr/bin/php7.4’ ‘artisan’ queue:work > ‘/dev/null’ 2>&1
No scheduled commands are ready to run.
storage/logs/laravel.log is showing this :
[2021-05-12 08:33:37] production.ERROR: The payload is invalid. {“userId”:1,“exception”:"[object] (Illuminate\Contracts\Encryption\DecryptException(code: 0): The payload is invalid. at /redacted/vendor/laravel/framework/src/Illuminate/Encryption/Encrypter.php:196) followed by a long stack trace
on both instances.
The installation is running on an Ubuntu 20.04 machine on a VPS, using PHP 7.4 and nginx 1.18.0
I have tried edge, brave, safari and chrome browsers in incognito with the same result. Can anyone please point me in any direction what to try next ?
Thank you
