Self-Hosting Issue and Cron Issue
I want alert that the link in your footer website to the self-hosted is broken… seems it try to load an URL with an invalid SSL so I AM also unable to access to the guide for now but I had a look in the past and I set my CronJob as follow:
/usr/local/emps/bin/php […]/invoice/public/ ninja:send-reminders
/usr/local/emps/bin/php […]/invoice/public/ ninja:send-invoices
If I do this command on SSH no error are showed but I have a recurring invoice with the status draft and should be sent on 01 June 2017 but still be on status draft and never is on recent recurring invoice.
Why? How to fix this?
Now status is pending because I edited the invoice but also done the cron by SSH never change this status.
Thanks, we’re working on it. Here’s a direct link to the guide:
http://docs.invoiceninja.com/en/latest/configure.html
Is the start date set for the invoice?
OK the cron should be:
/usr/local/emps/bin/php […]/invoice/artisan ninja:send-reminders
/usr/local/emps/bin/php […]/invoice/artisan ninja:send-invoices
but IF I do this by SSH I receive error:
PHP Fatal error: Class ‘PDO’ not found in /home/piadm/public_html/peopleinside_it/invoice/config/database.php on line 16
Solved just use
so replace /usr/local/emps/bin/php with php in my case solved.
Seems I cannot edit my post so I add a detail… for stop email cron alert I added to the end of the cron >/dev/null 2>&1
Thanks for sharing your solution!
