Self Hosted
Is it possible to move a local copy of invoice ninja to a hosting server?
I have tried but I just get a blank screen.
You should be able to transfer your data and settings using the JSON import/export
I’m still getting just a blank screen - http://invoice.salemconstruction.co.uk
any ideas what is causing this?
if I put an index.html in the <Public> folders it serves the page, I’m not sure it is parsing php?
You may want to try setting up a test phpinfo page
@hillel test.php works fine, maybe you can tell what is wrong from the info? - http://invoice.salemconstruction.co.uk/public/test.php
Same issue here. I’m hosting invoiceninja inside docker according to https://github.com/invoiceninja/dockerfiles/tree/master/docker-compose
It worked flawless for a year but since a few weeks ago, all I get is a blank screen as described by @sancler-property
Are there any errors in the web server error log?
Check the .env file, maybe you added some long text with spaces without using " at the beginning and at the end
The .env file is very picky about spaces
This won’t work:
MAIL_FROM_NAME=Invoice Ninja
This will work:
MAIL_FROM_NAME=‘Invoice Ninja’
Having a bad .env file gets you a blank screen
