I have just installed the self hosted IN via Softaculous on my Siteground server. Everything went fine but the version installed is 2.4.8.1 instead of 2.4.9.6 as indicated on Softaculous.
I did try to do an automatic update via Softaculous but, after the successful update, according to Softaculous, I get a parse error :
Parse error: syntax error, unexpected '[' in ../public_html/mydomain.com/vendor/guzzlehttp/psr7/src/functions.php on line 77
I can’t access …/public/update
I did contact Siteground tech support :
Now the Softaculous update should work normally however in some cases some extra steps may be needed in order to fully upgrade the application, so in this case after you restore the application you could try to manually upgrade it to the latest version.
I did try to download the self hosted package I copy it over the files on my domain but I still have the same parsing error.
The Siteground tech guy mention that, in some cases extra steps may be needed !!! What would that be ?
Thanks for your support
BTW, I have a valid licence bought during the Softaculous install process
Alexandre
