Version ie <v5.10.30>
Checklist
- Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja? NO
- Have you searched existing issues? YES
- Have you inspected the logs in storage/logs/laravel.log for any errors? YES
Describe the bug
I am trying to get the PDF rendering to work on localhost, I have generated a fake domain “invoiceninja.test” and am pointing it to my ip in the drivers/hosts file on my pc, which is working to access invoice ninja via the browser, however there is still no pdf, I then saw a commented line in the .env file “#SNAPPDF_CHROMIUM_PATH=/usr/bin/google-chrome-stable” which I uncommented and then the docker won’t build or start and says the following : app-1 | /bin/sh: 0: Illegal option -. I would like some assistance to get this working as I cannot seem to do it.
Steps To Reproduce
Run a fresh install of invoiceninja docker, uncomment the following line in the .env
Expected Behavior
PDFs to be generated
Additional context
I have also had a look at the console logs in the browser when I click to view the pdf and they are as follows.
bundle.Dp8oIWDU.js:145
GET http://invoiceninja.test/client/invoice/tVInUILJNpw0B5RhQmByn7RJrji409Lq/download_pdf 500 (Internal Server Error)
(anonymous) @ bundle.Dp8oIWDU.js:145
xhr @ bundle.Dp8oIWDU.js:145
tAe @ bundle.Dp8oIWDU.js:147
_request @ bundle.Dp8oIWDU.js:148
request @ bundle.Dp8oIWDU.js:147
(anonymous) @ bundle.Dp8oIWDU.js:143
Qe @ bundle.Dp8oIWDU.js:419
queryFn @ InvoiceViewer-DSDa_EFe.js:1
p @ bundle.Dp8oIWDU.js:395
f @ bundle.Dp8oIWDU.js:395
VWe @ bundle.Dp8oIWDU.js:395
e.fetch @ bundle.Dp8oIWDU.js:395
e.fetchQuery @ bundle.Dp8oIWDU.js:395
(anonymous) @ InvoiceViewer-DSDa_EFe.js:1
yT @ bundle.Dp8oIWDU.js:57
Rx @ bundle.Dp8oIWDU.js:57
(anonymous) @ bundle.Dp8oIWDU.js:57
E @ bundle.Dp8oIWDU.js:42
B @ bundle.Dp8oIWDU.js:42
bundle.Dp8oIWDU.js:419 Qs {message: ‘Request failed with status code 500’, name: ‘AxiosError’, code: ‘ERR_BAD_RESPONSE’, config: {…}, request: XMLHttpRequest, …}code: "ERR_BAD_RESPONSE"config: {transitional: {…}, adapter: Array(3), transformRequest: Array(1), transformResponse: Array(1), timeout: 0, …}message: "Request failed with status code 500"name: "AxiosError"request: XMLHttpRequest {onreadystatechange: null, readyState: 4, timeout: 0, withCredentials: false, upload: XMLHttpRequestUpload, …}response: {data: ArrayBuffer(131), status: 500, statusText: ‘Internal Server Error’, headers: np, config: {…}, …}status: 500stack: “AxiosError: Request failed with status code 500\n at IVe (http://invoiceninja.test/bundle.Dp8oIWDU.js:145:1045)\n at XMLHttpRequest.v (http://invoiceninja.test/bundle.Dp8oIWDU.js:145:5723)\n at QI.request (http://invoiceninja.test/bundle.Dp8oIWDU.js:147:2085)”[[Prototype]]: Error
(anonymous) @ bundle.Dp8oIWDU.js:419
Promise.then
Np7BB03RjKPrfLhxe1itWeXJggWDWN8fcr5dkLBa.png:1
GET http://192.168.0.248:8012/storage/z1s6SWkehhlvensSfdCdmoGAy8thGXjP/Np7BB03RjKPrfLhxe1itWeXJggWDWN8fcr5dkLBa.png net::ERR_CONNECTION_REFUSED
Screenshots
Logs
#40 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Sentry\Laravel\Http\FlushEventsMiddleware->handle()
#41 /var/www/html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#42 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#43 /var/www/html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#44 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#45 /var/www/html/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#46 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Livewire\Features\SupportDisablingBackButtonCache\DisableBackButtonCacheMiddleware->handle()
#47 /var/www/html/app/Http/Middleware/Cors.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#48 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): App\Http\Middleware\Cors->handle()
#49 /var/www/html/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(58): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#50 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Http\Middleware\TrustProxies->handle()
#51 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#53 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#54 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#55 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(51): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#56 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#57 /var/www/html/vendor/laravel/framework/src/Illuminate/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#58 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Http\Middleware\ValidatePostSize->handle()
#59 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(110): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#60 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#61 /var/www/html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(79): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#62 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Sentry\Laravel\Tracing\Middleware->handle()
#63 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(127): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#64 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\Pipeline\Pipeline->then()
#65 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(145): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#66 /var/www/html/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle()
#67 {main}
[2025-04-02 14:09:29] production.ERROR: Unable to generate the raw PDF => Browser binary not found. Make sure you download it or set using setChromiumPath(). {“userId”:1,“exception”:”[object] (App\Exceptions\FilePermissionsFailure(code: 0): Unable to generate the raw PDF => Browser binary not found. Make sure you download it or set using setChromiumPath(). at /var/www/html/app/Jobs/Entity/CreateRawPdf.php:148)
#0 /var/www/html/app/Jobs/Entity/CreateRawPdf.php(103): App\Jobs\Entity\CreateRawPdf->generatePdf()
#1 /var/www/html/app/Http/Controllers/InvoiceController.php(866): App\Jobs\Entity\CreateRawPdf->handle()
#2 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\InvoiceController->downloadPdf()
#3 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(44): Illuminate\Routing\Controller->callAction()
#4 /var/www/html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch()
#5 /var/www/html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(18): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#6 /var/www/html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch()
#7 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(266): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch()
#8 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(212): Illuminate\Routing\Route->runController()
#9 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(808): Illuminate\Routing\Route->run()
#10 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(170): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#11 /var/www/html/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#12 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): App\Http\Middleware\QueryLogging->handle()
#13 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(51): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#14 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#15 /var/www/html/app/Http/Middleware/TokenAuth.php(102): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#16 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): App\Http\Middleware\TokenAuth->handle()
#17 /var/www/html/app/Http/Middleware/SetInviteDb.php(81): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#18 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): App\Http\Middleware\SetInviteDb->handle()
#19 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(88): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#21 /var/www/html/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#22 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#23 /var/www/html/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#25 /var/www/html/app/Http/Middleware/SessionDomains.php(30): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): App\Http\Middleware\SessionDomains->handle()
#27 /var/www/html/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#28 /var/www/html/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
#29 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Session\Middleware\StartSession->handle()
#30 /var/www/html/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(75): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#31 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(209): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#32 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(127): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#33 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(807): Illuminate\Pipeline\Pipeline->then()
#34 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(786): Illuminate\Routing\Router->runRouteWithinStack()
#35 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(750): Illuminate\Routing\Router->runRoute()
#36 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(739): Illuminate\Routing\Router->dispatchToRoute()
#37 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(201): Illuminate\Routing\Router->dispatch()
#38 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(170): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#39 /var/www/html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/FlushEventsMiddleware.php(13): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#67 {main}
