When starting the beta app and trying to connect to my self-hosted instance it delivers a strange error message:
no host specified in URI …/api/v1/login?include=tax_rates&include_static=true
Any idea on how this comes up and how to solve this?
From the error it seems like something may be wrong with the URL, can you email the value you’re using to contact@invoiceninja.com.
Note: please make sure you’re using the latest version of the web app (v4.5.1).
the moment you mentioned the URL… I realized I switched the suffix from .com to .de and could log in… sorry for that stupid mistake including question…
Actually another error message came up saying deserializing failed… complete messsage again as screenshot:
Hmm… I’m not sure, I haven’t seen this error before.
a) yes
b) yes
c) no
Can you try changing this line:
https://github.com/invoiceninja/invoiceninja/blob/master/app/Libraries/Utils.php#L518
To
})->values();
Bam! That did the trick. Awesome!
So many thanks!
Thanks, good to know!
We’ll look into including this fix with our next release.
I just need to understand why the problem doesn’t affect everyone…
Running 4.5.14 and latest ISO app. having a similar issue with logging in.
I checked that the line in the utils was correct.
In the web app on Settings > User Details are the fields filled in?
Yes, all my user info is filled out.
<a href="https://ibb.co/Fn0XCsf"><img src="https://i.ibb.co/7bRQLgT/Annotation-2019-11-28-071742.png" alt="Annotation-2019-11-28-071742" border="0"></a>
What do you see if your run this SQL query
select id, email, first_name from users;
