Since an update a couple versions back, I’ve noticed that IN keeps logging me out every single time I close the window. Nothing’s changed as far as cookie settings in my browser, and it used to only do that every few hours.
I think I remember seeing a post somewhere about an .env setting to change when it logs you out, but for the life of me I can’t find it.
How work the 'lifetime' => env('SESSION_LIFETIME', (60 * 8)), variable ?
Does it mean 8 hours ? ?
I’d like to set my timeout to 3-4 hours…
Also When I edit an invoice does it have some autosave feature ? ?
I ask this because sometime I edit an invoice and the phone ring and I go out of my house and comeback few hours later so if I’m logged out and I did not save my invoice I would lose all my edit being logged out.
Not sure if they use that particular variable anymore unless SESSION_EXPIRE_ON_CLOSE is set to false.
It’s handled in the .env file with AUTO_LOGOUT_SECONDS (I have mine set to 3600, or one hour), and I think there’s also a REMEMBER_ME setting that can be put to true if you want it to keep you logged in indefinitely.
As for an autosave, I don’t think they have one. Best practice might be to just click “save draft” if you get pulled away in the middle of creating an invoice.
I’m a little bit confused, what I would like to do is to have my session open indefinitely until I close my tab/windows with Invoice Ninja ? Does it is possible to do ? ?
"Browsers only destroy session cookies when the entire browser process is exited. There is no reliable method to determine if/when a user has closed a tab. There is anonbeforeunloadhandler you can attach to, and hopefully manage to make an ajax call to the server to say the tab's closing, but it's not reliable.
And what if the user has two or more tables open on your site? If they close one tab, the other one would effectively be logged out, even though the user fully intended to keep on using your site."
So long story short, having the session end when you close the tab instead of the entire browser is likely not possible in any reliable fashion.
Ahhhh you’re so right I was searching high and low and overlooked this rookie mistake since I just pasted the line from Github and did not think to uncomment the code line…
