Hi all,
I have customized one invoice template and that works ok. However, I need to have another customized invoice template. How can I do that?
My first thought was to add another row (by copying an existing one) in the invoice_designs table, but after I did that, my changes on that additional template are saved within the Custom template… What confused me is that the row for the Custom design does not contain the pdfmake code for that template, just the value Null. I wasn’t able to find where the code for that custom template is located.
It would be great if we could have the typical CRUD functionality for invoice templates and not just this limitation of having just 1 custom template…
Thank you in advance for your help,
Ivan
