Hi, I’m trying tu use zapier to connect to my self-hosted version.
I received the following message :
“authentication failed: request to https://mydomain/public/api/v1/ping?v2=true failed, reason: unable to verify the first certificate”.
Do you have an idea ?
Thank you
How did you create the SSL cert? You may want to use letencrypt.
Thanks for your answer.
I used ssls.com to create my certificate.
Is it necessary to use letsencrypt ?
Thank You
I changed to letsencrypt but now I have this message :
authentication failed: Got 404 calling GET https://mydomain.com/public/api/v1/ping?v2=true, expected 2xx.
I searched on the forum but it seems that I’m using the latest version of InvoiceNinja (4.5.15).
6
If you want to email the URL you use to login to the app to contact@invoiceninja.com I can confirm if your API URL is correct.
I just emailed the URL to the provided address.
Thank you
8
Thanks, I believe you need to remove /public from the URL
Thank you, it works perfectly.
10
