Screenshots for Autobilling "Enabled by Default"
As per the documentation about Auto Billing on the page below, does anyone have any screenshots of the client portal when paying so it’s possible to see what the auto-billing fields look like when “Enabled by default” is turned on?
Enabled by default - The client will be given the option to allow payment methods to be stored with the radio box selected.
https://invoiceninja.github.io/docs/basic-settings/#company_details
I don’t have any screenshots available but with this option a checkbox is shown which gives your client the option to save their card on file.
@bruce
If you use optin/optout (Enabled by default / Disabled by default)
When the client views the Recurring invoices, they will have the option to enabled or disable autobilling.
The setting you configure will be the initial value set on the Recurring invoice.
