(Resolved)Un-filtered Invoice view no longer showing "Draft" invoices
This wasn’t an issue not long ago since I use this view almost daily.
In the hosted application, I’ll convert a Quote to an Invoice and then switch to the Invoices view, where the new Draft invoice isn’t visible in the unfiltered Invoices view. When I filter on “Draft” status, they show up…along with all my Deleted invoices for some reason. See attached.
Unfiltered Invoices View, excluding new Draft invoices:
Missing Draft invoices revealed:
Sorry for the trouble!
Please send an email to contact@invoiceninja.com and we’ll look into it.
At your suggestion, I emailed that mailbox a link to this post so they are aware of the issue.
Resolved. The issue was solved after I sorted the column by status instead of by Invoice Number. I was expecting to see the new invoices at the top of the view (sorted by number) but my numbering prefix put these particular invoices towards the bottom in numberical order. So, it was my bad!
