Hi! I’m trying to setup a self hosted invoice ninja system by following this guide:
https://invoiceninja.github.io/selfhost.html#installing-invoice-ninja
However, as soon as I get to the part where you open the web browser and go to /setup. I get greeted by the following: (all requirements are met… but I can’t continue)
I am using PHP version 7.4.7 using Plesk, and verified that all the required extensions are indeed installed.
(also tried another browser just to be sure )
There are no PHP error logs, there is a laravel.log file in /storage/logs/. However, this is not much help:
Contents:
[2020-07-06 17:49:44] local.INFO: db fails
[2020-07-06 17:50:52] local.INFO: db fails
[2020-07-06 17:54:02] local.INFO: db fails
[2020-07-06 17:57:36] local.INFO: db fails
[2020-07-06 17:57:56] local.INFO: db fails
(guessing the cronjob is properly setup )
I have no idea how to troubleshoot further… Any help would be appreciated!
