Reports remove default columns
Hi there,
In reports there are default columns and it’s so easy to add a new one, but you can’t unset default ?
thanks you.
You should be able to remove columns in the edit column popup?
there are a fix values that I can’t modify, just add new ones and “restore” default columns. But I can’t remove default values.
Have you tried clicking the x and then clicking save?
At first time I can’t locate any X
but…! after you say press X, i found it.
Little bit hard to find it.
thanks you.
Thanks for the screenshots!
I think it’s a bug, we’ll work to correct it.
Note: it may help to change the accent color on Settings > User details.
Thanks you, knowing x’s are hidden in left side I will press it without any color changes.
Thanks again
