Report functions fail with API 409 error
Hi
When trying to run any report nothing happens and I get repeated API 409 errors.
No matter what report I try, export or preview I get the “Processing” popup but that is all. I have everything else running well including email integration and pdf generation and have been using the system for 3+ months.
Are there logs that may show more info?
Self hosted, Ubuntu / Proxmox v Latest Build - 2024-08-07
I suggest checking the browser console for errors as well as storage/logs.
You may also want to test with the desktop app.
Hi
Yes the Windows app does no show this issue.
I will use that as my interface.
thanks
Are you using the reports in the desktop app or Settings > Import/Export?
Feel free to create an issue on GiHub to track the problem in the web app.
