I have set my smtp mail-settings during the setup process and see that I can change them in the .env file. But I am wondering if I can set a reply-to address for the client/invoice mails somewhere?
Thanks,
Gijs
Thanks,
Gijs
You can specify the reply-to address in the admin portal on Settings > Email Settings
ah great, I didn’t expect it there because all other settings are in the .env file.
Thanks,
Gijs
At some point, all changes would be possible using UI. Nobody likes to edit .env files.
