Release 5.6.30 not build/released on docker
I don’t know if it’s me doing something wrong but I don’t see version 5.6.30 released on docker hub as invoiceninja normally is.
Is this wrong or has an error happened in the deployment pipeline?
Thanks for a great application.
// Mark
Thanks for letting us know, @david any ideas?
@david - No news about the missing release on docker?
Sorry for the delay, the release should now be available.
@hillel thanks I can see it and also the later 5.6.31…
Thanks for the help.
Hi guys,
Don’t what to make any trouble but just to make your guys aware of this problem.
Now with version 5.7’s patch releases .1 + .2 + .3 + .4 is not release in the dockerfiles repo and thereby not build and pushed on dockerhub.
Also my instance said that I need to upgrade from 5.6.31 to 5.7.3 - den updating (docker-compose down + pull + up) now it’s saying that I need and update from 5.7.0 or 5.7.3 (and it don’t see the current release 5.7.4) so there is 2 problems as I see it with the docker pipeline/actions to docker images.
  1. not reporting correct available version 5.7.3 (current release in main is 5.7.4)
  2. not building every release from the invoiceninja/invoiceninja
@david can you please advise?
