Registration page not working
The registration page is not working.
I’ve turned on the client registration setting on client portal - https://sub.domain.com/client/register
Attached a screenshot.
There’s a login disabled header shown if i were to click on the register button.
@david any thoughts?
@user777
It appears your required fields have not populated.
you’ll want to open up your database and in the companies table insert the following into the column
client_registration_fields
[{"key":"first_name","required":true},{"key":"last_name","required":true},{"key":"email","required":true},{"key":"phone","required":false},{"key":"password","required":true},{"key":"name","required":false},{"key":"website","required":false},{"key":"address1","required":false},{"key":"address2","required":false},{"key":"city","required":false},{"key":"state","required":false},{"key":"postal_code","required":false},{"key":"country_id","required":false},{"key":"custom_value1","required":false},{"key":"custom_value2","required":false},{"key":"custom_value3","required":false},{"key":"custom_value4","required":false},{"key":"public_notes","required":false},{"key":"vat_number","required":false}]
Once that has been done, refresh the data in your application, and you’ll be able to see the fields you can select to display for the registration page.
Got it working, thanks @david
