I just upgraded to the newest version - had to upgrade to php 7.0 too.
When I tried the cronjob in order to be sure everything is working fine, I got shocked because InvoiceNinja just sent me 6 mails with invoices the system sent - although I thought there would not be any to send, as the output of the script says too.
Despite that, the invoices have been created in the system. It seems that there’s a problem with the selected "anual = “Jährlich”-term, whereas it appears two times and if you select the upper one, the time schedule seems rather like “half-anual”. I don’t have any idea why this is this way? And why is it now a problem, me running the script manually? This morning - before the update - the cronjob run of the script had not sent the mails out…
In general there seems to be a problem with the labelling of the recurring schemes, “Six months” = “Halbjährlich” results actually in a 3 months scheme, it’s not a translation problem. Just tested it with english language, the result is the same…
| id | name |
| 1 | Weekly |
| 2 | Two weeks |
| 3 | Four weeks |
| 4 | Monthly |
| 5 | Two months |
| 6 | Three months |
| 7 | Four months |
| 8 | Six months |
| 9 | Annually |
There was a problem with the update script where it wasn’t calling /update at the end, I’d suggest checking that you’re using the latest version of the script.
