Recurring Invoices API
Is it possible to create and modify recurring invoices via the API? We are looking to use Invoice Ninja as the default invoicing and payment gateway but using recurring invoices is critical via the API.
It isn’t documented but it works, you need to make sure the following fields are set: is_recurring, frequency_id, start_date and end_date.
curl -X POST ninja.dev/api/v1/invoices -H “Content-Type:application/json” -d ‘{“frequency_id”:1, “is_recurring”:true,“start_date”:“2016-05-01”,“end_date”:“2016-05-01”, “email":"test@example.com”, “product_key”:“ITEM”}’ -H “X-Ninja-Token:TOKEN” -H “X-Requested-With: XMLHttpRequest”
Wrong Post Sorry
