The results of this cron is:
No scheduled commands are ready to run.
Configuration cache cleared!
Configuration cached successfully!
Route cache cleared!
Routes cached successfully!
Files cached successfully!
No invoice is sent and today is 2 January.
Why pending recurring invoice is not sent and generated?
I installed by FTP as curently cannot use softaculous for install the Beta V5 .
It’s a bug, it’s only me or you can help to understand why I see pending recurring invoice generated from me in 2020 but also if cronjob is set and the recurring invoice is pending, no invoice was generated yesterday…
So today tried the cron manually and the result is what I say.
What is wrong?
The cronjob is correct? I think yes as it gives results. I need a different cronjob for recurring invoice?
The status is pending (In attesa).
The cron run every morning at 8:00 AM just one time a day… but even if I run manually and I have a pending invoice this recurring invoice should be generated.
Hi @david@ben currently I’m with Version 5.0.54-C39 and recurring invoice still not working.
No reply since my last message.
I have a pening invoice with the pending status and the send date 1 febrary 2021 and a cron than run at 08:05 AM every day.
Maybe the previous command I mentioneted for send recurring was not correct.
The correct cron seems to be: php invoice.domain.ext/artisan ninja:send-recurring
I get an error when I do this:
In Connection.php line 678:
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'paid_to_date' in 'field list' (SQL: insert into
`invoices` (`status_id`, `discount`, `is_amount_discount`, `po_number`, `footer`, `terms`, `public_not
es`, `private_notes`, `due_date`, `is_deleted`, `line_items`, `tax_name1`, `tax_rate1`, `tax_name2`, `t
ax_rate2`, `tax_name3`, `tax_rate3`, `custom_value1`, `custom_value2`, `custom_value3`, `custom_value4`
, `amount`, `user_id`, `assigned_user_id`, `company_id`, `recurring_id`, `client_id`, `auto_bill_enable
d`, `paid_to_date`, `date`, `next_send_date`, `updated_at`, `created_at`) values (1, 0, 0, ?, ?, ?, ?,
?, ?, 0, [{"product_key":"L A S M F C","notes":"A I A
ativo","cost":800,"quantity":1,"tax_name1":"","tax_rate1":0,"tax_name2":"","tax_rate2":0,"tax_name3":""
,"tax_rate3":0,"custom_value1":"","custom_value2":"","custom_value3":"","custom_value4":"","discount":0
,"type_id":"1","createdAt":1607246645849000,"is_amount_discount":false,"sort_id":"0","line_total":800,"
date":""},{"product_key":"Spese condominio","notes":"Spese condominio","cost":180,"quantity":1,"tax_nam
e1":"","tax_rate1":0,"tax_name2":"","tax_rate2":0,"tax_name3":"","tax_rate3":0,"custom_value1":"","cust
om_value2":"","custom_value3":"","custom_value4":"","discount":0,"type_id":"1","createdAt":160724664809
3000,"is_amount_discount":false,"sort_id":"0","line_total":180,"date":""}], ?, 0.000, ?, 0.000, ?, 0.00
0, ?, ?, ?, ?, 980.0000, 1, ?, 1, 1, 1, 1, 0, 2021-02-01, ?, 2021-02-01 15:41:13.619092, 2021-02-01 15:
41:13.619092))
than:
In Exception.php line 18:
and:
In PDOConnection.php line 78:
Any solution?
Now also manual invoice doesn’t work anymore:
Update: I’m removing the software from my VPS, too many issues.
