Recurring Invoice as a concept
I was wondering if it’s possible to make recurring invoices, but not to send them rightaway. Just to doublecheck everything is right I’d like that the invoice is made as a concept, but not emailed immediately.
So i should do the email manually.
Yes, you can disable auto-email in the workflow settings on Settings > Invoice Settings
