Recurrent invoice problem in February
It looks like there’s a bug when dealing with “Monthly” invoices in February. My recurrent invoices were created with the date “03-01-2018” instead of “02-28-2018” (last day of the month or similar). I had to change all them manually. Is there anything I’m missing?
Regards,
Gabriel Crespo
We support setting the due date to the last date of the month however we don’t support sending the invoice on the last day of the month. Until it’s supported you’d need to send invoices on the 28th day of the month.
FYI… we’ll look into fixing this in our next major release.
Hi Hillel,
Thank you for the info. It would be really nice to have that fixed. The critical point is not the due date or the sending date, but the generation date (at least in Spain, there’s a big difference if the invoice is generated February, 28th or March, 1st).
Regards,
Gabriel Crespo
I had this problem too. Because my invoice start dates were Jan 31 and due the 1st day of the month. Because of this, the system decides all the invoices that were supposed to be due March 1, are now due April 1. So now I have to change all the invoices to be due on the 2nd instead of the 1st, which is not a great option.
It would be great if I could have some invoices autobill on the send date, while others autobill on the due date. I’m only sending the invoice out a day early because the system won’t allow the start and due dates be the same.
Are you using invoiceninja.com or are you self hosting?
invoiceninja.com
Which setting are you using for the due date on the recurring invoice?
They were set to the 1st of the month. Autobill is set to bill on Due Date
If you want the invoices to be billed on the same day they’re sent you can select ‘Use client payment terms’ and set the payment terms to ‘Net 0’.
Ahhh! That’s exactly what I needed. Thank you!!
