Recommended Dev IDE For Contributing To V5 Project
I looking into what software IDE’s are used (if any) that help with building a project of this type. I’ve never used the Laravel PHP framework before, so there will be a learning curve and I’m curious what others use who contribute to this project use to help them code as efficiently as possible.
@DaveFrank
It comes down to personal preference. I prefer a minimal interface so i use Sublime Text.
If you prefer something that can really assist you to drill down into the code you may want to checkout PHPStorm it is a beast to learn but does have a lot of features.
