React Default Due Date
The React invoicing screen doesn’t apply the default terms. The flutter web app did but now I have to make sure and enter a due date. Otherwise it is set as the same day.
They have to be setup in the default settings. Today I just noticed my default invoice numbering was reset and had to fix it in the react settings. Unfortunately, you might need to apply it again in the react settings.
Thanks for the tip. I checked those settings and it is setting my default due date correctly but only after sending.
I knew that happened before but missed it this time :slight_smile:
