I was in the process of building a new quote pattern when I realized that the counter used when auto generating a quote number somehow got unlinked from the counter in the Generated Numbers panel. It seems like at some point it “borrowed” the invoice counter, which was 3063, and it’s been incrementing by 1 from there ever since on its own, without being influenced by its own counter settings:
In the meantime, my invoice counter hasn’t gone up at all, it’s still at 3063 - so it’s not like the quotes just happened to get linked to the invoice counter; they are following a new, uncontrollable path.
I tried resetting the quote counter to 1 and running php artisan optimize: it didn’t work, the created quotes are still calculating in the 3K range and the quote counter is still at 1…! Other pattern rules seem to work OK with quote naming, but the counter is running amok.
As far as I can tell, other counters are working fine on their own: I tested the invoices counter and the projects counter and both add up one increment at the time to their own counter like intended.
Thanks in advance for your help!
EDIT:
I made sure that the counter sharing between quotes and invoices is disabled:
Thanks for the suggestion, but I actually tried adding the {$counter} variable as a potential fix, since the wonky behaviour happens with nothing in the Number Pattern field:
The counter is stuck at 1, but it used to work for at least one test quote, which was numbered 0001. I then testing converting that test quote to a test invoice, and after that the counter got broken, if that helps to know the steps.
Is there anything I can try to edit in the database in order to possibly reset this?
EDIT: The “bad” Quote counter is back at 3066 after I tried changing the pattern: it reset itself to the actual active counter on the Invoices Pattern.
EDIT2: I checked the database under companies > settings and I can confirm that my quote counter is stuck at 1, it’s not just a display issue:
So there must be something happening somewhere else which makes my quotes get their numbers from the invoices counter.
Maybe this is related to the shared counter option not being read correctly? I think it behaves as if I did in fact set it to “ON”, even though the db reads "shared_invoice_quote_counter":false.
Thanks for your suggestion, but that did not fix it. I created a few more quotes and they all follow the invoice counter. The invoice counter itself did not go up until I created a new invoice, and then it got updated to match the sequence. Sow that’s how it went:
Quote 3066 → Quote 3067 → Invoice 3068 → Quote 3069 (even though my settings are to not share the counter between invoices and quotes)
So I thought the quotes somehow had their own “ghost counter” initially based on the invoice counter, but in fact I now have the proof that they share the same counter behind the scenes, and creating an invoice refreshes the counter display to match where it’s really at.
Any other ideas on how I can reset this behaviour? My database is backed up every hour so I don’t mind getting my hands a little dirty if necessary, I can always revert to a previous state easily. I just want to fix this and be able to rely on the built-in counters!
then my quotes are back to following the invoice counter:
With that being said, I still have the quote counter stuck at 1 in the admin, even though it is incrementing the numbers in the actual quotes:
UPDATE 1:
I could also reproduce the bug on your hosted demo. I set the invoice counter at 999 and I turned on Shared Invoice/Credit counter, which gave me quote “#0999”, even though the quote counter was at “7”:
with the invoice/credit shared counter turned off, I also experience a stuck admin counter on your demo. Here are a couple of quotes incrementing in the 20s
