Hi.
Totals will say:
Popust 40%
instead of
Pupust 40%
Popust is a word for Discount.
If I change the client language to English is OK, but other language seems to have the problem.
Any idea?
Br,
Dali
Hi.
Totals will say:
Popust 40%
instead of
Pupust 40%
Any idea?
Br,
Dali
I’ve tested in croatian , serbian, but cannot recreate this.
Can you confirm you are seeing this on the PDF itself?
Yes, it’s on preview and PDF.
Strange indeed. I have 4 Companies on one InvoiceNinja install. It will happen on 3. One company is OK. Maybe there are some settings. As it is in total (only one line in Body HTML template) I don’t know even where to look for the problem.
If I create a client with Croatian language is the same problem.
Br,
Dali
The problem is that Settings/Account Management/Enable PDF Markdown should be ON.
When OFF there is a problem
Br,
Dali
I’ve got a fix in for the next release.
Changing the PDF markdown settings may cause other unintended side effects to your pdfs
