Queue/Cron not enabled
InvoiceNinja v5.8.9-C148
This is new install installed on a shared host via Softaculous.
My panel is DirectAdmin
My panel states that the cron is indeed there.
If you have SSH access I suggest running the cron from the CLI without the >> part to check the output.
When running artisan schedule:run most of the times I get return that no commands are ready to run, every so couple minutes it returns: 2024-01-14 08:25:20 Running [queue-size-job] … 53ms DONE
2024-01-14 08:25:20 Running [Callback] … 18ms DONE
On another note. I’m not sure if I am doing something wrong in my email setup, but it’s not sending out emails at all. I use the same details on Outlook and have no issues.
Loading /update?secret=secret may help remove the cron error.
There’s info here about emails: Free Source Available Invoicing, Expenses & Time-Tracking | Invoice Ninja
