Recently I have noticed that an orange triangle appeared in System asking for moving to queues instead of sync. I couldn’t find the exact command and a step by step guide on how to configure the queues/supervisor under Laravel for invoice ninja is not available. Someone please post a config for supervisor to get this working. I am on Ubuntu 20.04 LTS
Couldn’t make it work though. Was wondering how you made it work?
Secondly if it worked how is it different from php /var/www/invoice artisan queue:clear which I tried. It did remove the pending jobs but I don’t think it really worked instead I think it deleted those pending jobs.
Just to update: My configuration is based on #cron-configuration-1 specifically the LARAVEL/SUPERVISOR portion which advice to follow the guide at the LARAVEL docs.
