I don’t use the self hosted version and I’m going to upgrade to a paid plan
How do I change description of an invoice so that it doesn’t include the date but just the amount of hours spend on a task?
I know I can do this manually but how to do it automatic?
Alternatively how do I use the project name as the description with the amount of hours when adding tasks to invoice (would make the invoice less clustered) as many tasks are part of a larger project (the description is something I would like to use internally).
Is it possible to automate the invoicing of tasks (like recurring payments)?
With self hosting you can change the language files, with hosted you can create a custom design with the hard coded changes.
How and where do I do this?
I can't seem to find it on these two pages https://app.invoiceninja.com/settings/invoice_design# & https://app.invoiceninja.com/settings/customize_design
