Quantity Missing
I went to enter an invoice, and no matter what I do, quantity is no longer on each line item.
I have checked to make sure that the column wasn’t removed in the settings, and it wasn’t. I even updated that in case that helped the issue go away by removing 2 columns that I never used, but quantity still doesn’t show up.
Please advise.
Can you check that “Show product quantity” is enabled on Settings > Product Settings.
That did it. I think that I turned that off thinking it was involved with keeping track of inventory and not related to invoices. Apologies for the trouble, and thanks for the assistance!
Glad to hear it’s sorted, thanks for the update!
