Purchase Order Error 500
When I try to email Purchase Orders to vendors I get error 500.
Checking the logs reveals
[previous exception] [object] (PDOException(code: 42S02): SQLSTATE[42S02]: Base table or view not found: 1146 Table 'invoiceninja.purchaseOrders' doesn't exist at /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php:416)
#0 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(416): PDO->prepare()
#1 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(809): Illuminate\\Database\\Connection->Illuminate\\Database\\{closure}>
#2 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(776): Illuminate\\Database\\Connection->runQueryCallback()
#3 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(407): Illuminate\\Database\\Connection->run()
#4 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2751): Illuminate\\Database\\Connection->select()
#5 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2740): Illuminate\\Database\\Query\\Builder->runSelect()
#6 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3294): Illuminate\\Database\\Query\\Builder->Illuminate\\Database\\Q>
#7 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2739): Illuminate\\Database\\Query\\Builder->onceWithColumns()
#8 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3221): Illuminate\\Database\\Query\\Builder->get()
#9 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3149): Illuminate\\Database\\Query\\Builder->aggregate()
#10 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Validation/DatabasePresenceVerifier.php(54): Illuminate\\Database\\Query\\Builder->count()
#11 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Validation/Concerns/ValidatesAttributes.php(903): Illuminate\\Validation\\DatabasePresenceVeri>
#12 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Validation/Concerns/ValidatesAttributes.php(874): Illuminate\\Validation\\Validator->getExistC>
#13 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(657): Illuminate\\Validation\\Validator->validateExists()
#14 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(457): Illuminate\\Validation\\Validator->validateAttribute()
#15 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(492): Illuminate\\Validation\\Validator->passes()
#16 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Validation/ValidatesWhenResolvedTrait.php(31): Illuminate\\Validation\\Validator->fails()
#17 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Providers/FormRequestServiceProvider.php(30): Illuminate\\Foundation\\Http\\FormReq>
#18 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(1302): Illuminate\\Foundation\\Providers\\FormRequestServiceProvider->>
#19 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(1266): Illuminate\\Container\\Container->fireCallbackArray()
#20 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(1252): Illuminate\\Container\\Container->fireAfterResolvingCallbacks()
#21 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(813): Illuminate\\Container\\Container->fireResolvingCallbacks()
#22 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(957): Illuminate\\Container\\Container->resolve()
#23 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(731): Illuminate\\Foundation\\Application->resolve()
#24 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(942): Illuminate\\Container\\Container->make()
#25 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(85): Illuminate\\Foundation\\Application->make()
#26 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(50): Illuminate\\Routing\\ControllerDispatcher->transfor>
#27 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(29): Illuminate\\Routing\\ControllerDispatcher->resolveM>
#28 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(59): Illuminate\\Routing\\ControllerDispatcher->resolveClassM>
#29 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(40): Illuminate\\Routing\\ControllerDispatcher->resolveParame>
#30 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\\Routing\\Contr>
#31 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(19): Sentry\\Laravel\\Tracing\\Routing\\T>
#32 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\\Laravel\\Tracing\\>
#33 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(259): Sentry\\Laravel\\Tracing\\Routing\\TracingControllerDispatcherTracing->
#34 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\\Routing\\Route->runController()
#35 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(806): Illuminate\\Routing\\Route->run()
#36 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}()
#37 /var/www/invoiceninja/app/Http/Middleware/UserVerified.php(40): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#38 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\\Http\\Middleware\\UserVerified->handle()
#39 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(122): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipe>
#40 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(87): Illuminate\\Routing\\Middleware\\ThrottleRequests>
#41 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\\Routing\\Middleware\\ThrottleRequests->handle()
#42 /var/www/invoiceninja/app/Http/Middleware/QueryLogging.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#43 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\\Http\\Middleware\\QueryLogging->handle()
#44 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pip>
#45 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle()
#46 /var/www/invoiceninja/app/Http/Middleware/Locale.php(87): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#47 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\\Http\\Middleware\\Locale->handle()
#48 /var/www/invoiceninja/app/Http/Middleware/TokenAuth.php(101): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#49 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\\Http\\Middleware\\TokenAuth->handle()
#50 /var/www/invoiceninja/app/Http/Middleware/SetDb.php(40): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#51 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\\Http\\Middleware\\SetDb->handle()
#52 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#53 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(805): Illuminate\\Pipeline\\Pipeline->then()
#54 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(784): Illuminate\\Routing\\Router->runRouteWithinStack()
#55 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(748): Illuminate\\Routing\\Router->runRoute()
#56 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(737): Illuminate\\Routing\\Router->dispatchToRoute()
#57 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(200): Illuminate\\Routing\\Router->dispatch()
#58 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http>
#59 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipel>
#60 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\\Laravel\\Http\\SetRequestIpMiddleware->handle()
#61 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipelin>
#62 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\\Laravel\\Http\\SetRequestMiddleware->handle()
#63 /var/www/invoiceninja/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\\Pipeline\\>
#64 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Livewire\\Features\\SupportDisablingBackButtonCache\\DisableBackBu>
#65 /var/www/invoiceninja/app/Http/Middleware/Cors.php(24): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#66 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\\Http\\Middleware\\Cors->handle()
#67 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{c>
#68 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\\Http\\Middleware\\TrustProxies->handle()
#69 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illumina>
#70 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\\Foundation\\Http\\Mi>
#71 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\\Foundation\\Http\\Middleware\\ConvertEmptyStringsToNul>
#72 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illumina>
#73 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\\Foundation\\Http\\Middleware\\Tran>
#74 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\\Foundation\\Http\\Middleware\\TrimStrings->handle()
#75 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Pipeline\\Pipeline->Illuminat>
#76 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle>
#77 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(99): Illuminate\\Pipeline\\Pip>
#78 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMai>
#79 /var/www/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(87): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{clo>
#80 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\\Laravel\\Tracing\\Middleware->handle()
#81 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#82 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(175): Illuminate\\Pipeline\\Pipeline->then()
#83 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(144): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRoute>
#84 /var/www/invoiceninja/public/index.php(56): Illuminate\\Foundation\\Http\\Kernel->handle()
#85 {main}
I am running v5.8.15-M148.
Thanks.
It should help to update the macOS app to the latest version from the app store.
That did the trick. Thank you.
