I got a syntax error, unexpected end of file, expecting function (T_FUNCTION) or const (T_CONST) (View: /var/www/v3/resources/views/portal/ninja2020/quotes/show.blade.php)
When clients tries to view a Quotes or invoice.
I also got a 500 error for Viewing PDF of the Quotes and invoice’s
Can use some help
Client quotes Viewing error Log
[2020-07-24 10:36:24] local.ERROR: syntax error, unexpected end of file, expecting function (T_FUNCTION) or const (T_CONST) (View: /var/www/v3/resources/views/portal/ninja2020/quotes/show.blade.php) {“userId”:1,“exception”:"[object] (ErrorException(code: 0): syntax error, unexpected end of file, expecting function (T_FUNCTION) or const (T_CONST) (View: /var/www/v3/resources/views/portal/ninja2020/quotes/show.blade.php) at /var/www/v3/app/Events/Quote/QuoteWasUpdated.php:35)
#0 /var/www/v3/vendor/livewire/livewire/src/CompilerEngine.php(71): Illuminate\View\Engines\CompilerEngine->handleViewException()
#1 /var/www/v3/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php(47): Livewire\CompilerEngine->handleViewException()
#2 /var/www/v3/vendor/livewire/livewire/src/LivewireViewCompilerEngine.php(36): Illuminate\View\Engines\PhpEngine->evaluatePath()
#3 /var/www/v3/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php(59): Livewire\LivewireViewCompilerEngine->evaluatePath()
#4 /var/www/v3/vendor/laravel/framework/src/Illuminate/View/View.php(143): Illuminate\View\Engines\CompilerEngine->get()
#5 /var/www/v3/vendor/laravel/framework/src/Illuminate/View/View.php(126): Illuminate\View\View->getContents()
#6 /var/www/v3/vendor/laravel/framework/src/Illuminate/View/View.php(91): Illuminate\View\View->renderContents()
#7 /var/www/v3/vendor/laravel/framework/src/Illuminate/Http/Response.php(42): Illuminate\View\View->render()
#8 /var/www/v3/vendor/symfony/http-foundation/Response.php(205): Illuminate\Http\Response->setContent()
#9 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(749): Symfony\Component\HttpFoundation\Response->__construct()
#10 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(721): Illuminate\Routing\Router::toResponse()
#11 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(681): Illuminate\Routing\Router->prepareResponse()
#12 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#13 /var/www/v3/app/Http/Middleware/Locale.php(34): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#14 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\Locale->handle()
#15 /var/www/v3/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(43): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#16 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Auth\Middleware\Authenticate->handle()
#17 /var/www/v3/app/Http/Middleware/QueryLogging.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#18 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\QueryLogging->handle()
#19 /var/www/v3/app/Http/Middleware/StartupCheck.php(73): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\StartupCheck->handle()
#21 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#22 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#23 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(76): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#25 /var/www/v3/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#27 /var/www/v3/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(56): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#28 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Session\Middleware\StartSession->handle()
#29 /var/www/v3/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#30 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#31 /var/www/v3/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(66): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#33 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#34 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(683): Illuminate\Pipeline\Pipeline->then()
#35 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(658): Illuminate\Routing\Router->runRouteWithinStack()
#36 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(624): Illuminate\Routing\Router->runRoute()
#37 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(613): Illuminate\Routing\Router->dispatchToRoute()
#38 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(170): Illuminate\Routing\Router->dispatch()
#39 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#40 /var/www/v3/app/Http/Middleware/Cors.php(35): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\Cors->handle()
#42 /var/www/v3/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#43 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Fideloper\Proxy\TrustProxies->handle()
#44 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#45 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#46 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#47 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#48 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#50 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(63): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#51 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle()
#52 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#53 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(145): Illuminate\Pipeline\Pipeline->then()
#54 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#55 /var/www/v3/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle()
#56 {main}
PDF View error log:
2020-07-24 10:35:23] local.ERROR: The command “PATH=$PATH:/usr/local/bin NODE_PATH=npm root -g
node ‘/var/www/v3/vendor/spatie/browsershot/src/…/bin/browser.js’ ‘{“url”:“file:///tmp/1082994487-0659453001595586922/index.html”,“action”:“pdf”,“options”:{“args”:[],“viewport”:{“width”:800,“height”:600,“deviceScaleFactor”:1},“displayHeaderFooter”:false,“waitUntil”:“networkidle0”,“printBackground”:true}}’” failed.
Exit Code: 1(General error)
Working directory: /var/www/v3/public
Output:
Error Output:
sh: 1: npm: not found
{ Error: spawn EACCES
at _errnoException (util.js:1022:11)
at ChildProcess.spawn (internal/child_process.js:323:11)
at Object.exports.spawn (child_process.js:502:9)
at Launcher.launch (/var/www/v3/node_modules/puppeteer/lib/Launcher.js:132:40)
at <anonymous> code: 'EACCES', errno: 'EACCES', syscall: 'spawn' }
{“exception”:"[object] (Symfony\Component\Process\Exception\ProcessFailedException(code: 0): The command “PATH=$PATH:/usr/local/bin NODE_PATH=npm root -g
node ‘/var/www/v3/vendor/spatie/browsershot/src/…/bin/browser.js’ ‘{“url”:“file:\/\/\/tmp\/1082994487-0659453001595586922\/index.html”,“action”:“pdf”,“options”:{“args”:[],“viewport”:{“width”:800,“height”:600,“deviceScaleFactor”:1},“displayHeaderFooter”:false,“waitUntil”:“networkidle0”,“printBackground”:true}}’” failed.
Output:
Error Output:
at /var/www/v3/vendor/spatie/browsershot/src/Browsershot.php:738)
#0 /var/www/v3/vendor/spatie/browsershot/src/Browsershot.php(532): Spatie\Browsershot\Browsershot->callBrowser()
#1 /var/www/v3/app/Utils/Traits/Pdf/PdfMaker.php(43): Spatie\Browsershot\Browsershot->pdf()
#2 /var/www/v3/app/Jobs/Quote/CreateQuotePdf.php(87): App\Jobs\Quote\CreateQuotePdf->makePdf()
#3 [internal function]: App\Jobs\Quote\CreateQuotePdf->handle()
#4 /var/www/v3/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(32): call_user_func_array()
#5 /var/www/v3/vendor/laravel/framework/src/Illuminate/Container/Util.php(37): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#6 /var/www/v3/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(90): Illuminate\Container\Util::unwrapIfClosure()
#7 /var/www/v3/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(34): Illuminate\Container\BoundMethod::callBoundMethod()
#8 /var/www/v3/vendor/laravel/framework/src/Illuminate/Container/Container.php(590): Illuminate\Container\BoundMethod::call()
#9 /var/www/v3/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(94): Illuminate\Container\Container->call()
#10 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Bus\Dispatcher->Illuminate\Bus\{closure}()
#11 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#12 /var/www/v3/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(98): Illuminate\Pipeline\Pipeline->then()
#13 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Bus/Dispatchable.php(26): Illuminate\Bus\Dispatcher->dispatchNow()
#14 /var/www/v3/app/Services/Quote/GetQuotePdf.php(46): App\Jobs\Quote\CreateQuotePdf::dispatchNow()
#15 /var/www/v3/app/Services/Quote/QuoteService.php(69): App\Services\Quote\GetQuotePdf->run()
#16 /var/www/v3/app/Http/Controllers/QuoteController.php(700): App\Services\Quote\QuoteService->getQuotePdf()
#17 [internal function]: App\Http\Controllers\QuoteController->downloadPdf()
#18 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): call_user_func_array()
#19 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#20 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Route.php(219): Illuminate\Routing\ControllerDispatcher->dispatch()
#21 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Route.php(176): Illuminate\Routing\Route->runController()
#22 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(681): Illuminate\Routing\Route->run()
#23 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#24 /var/www/v3/app/Http/Middleware/SetInviteDb.php(52): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#25 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\SetInviteDb->handle()
#26 /var/www/v3/app/Http/Middleware/QueryLogging.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#27 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\QueryLogging->handle()
#28 /var/www/v3/app/Http/Middleware/StartupCheck.php(73): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\StartupCheck->handle()
#30 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#31 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#32 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(76): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#33 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#34 /var/www/v3/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#35 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#36 /var/www/v3/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(56): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#37 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Session\Middleware\StartSession->handle()
#38 /var/www/v3/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#39 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#40 /var/www/v3/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(66): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#42 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#43 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(683): Illuminate\Pipeline\Pipeline->then()
#44 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(658): Illuminate\Routing\Router->runRouteWithinStack()
#45 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(624): Illuminate\Routing\Router->runRoute()
#46 /var/www/v3/vendor/laravel/framework/src/Illuminate/Routing/Router.php(613): Illuminate\Routing\Router->dispatchToRoute()
#47 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(170): Illuminate\Routing\Router->dispatch()
#48 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#49 /var/www/v3/app/Http/Middleware/Cors.php(35): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#50 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\Cors->handle()
#51 /var/www/v3/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Fideloper\Proxy\TrustProxies->handle()
#53 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#54 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#55 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#56 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#57 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#58 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#59 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(63): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#60 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle()
#61 /var/www/v3/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#62 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(145): Illuminate\Pipeline\Pipeline->then()
#63 /var/www/v3/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#64 /var/www/v3/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle()
#65 {main}
