Project field in Quote Details is not available
Hi there,
i need to mention the Project name in the entity details table but unfortuantely for some reason that works only on invoices and there is no Project in Add Field for Quote details, i need to have that on quotes too, is there any workaround other than creating a custom field since i’m out of them and there are only four custom available
or this will be fixed in a near update ?
also it would be so great to add a Receipt PDF creation function since that is the only drawback in the system
Thank you !
We’ll look into adding the project field here.
With the latest version you can use templates to generate a receipt.
