Spontaneous migration to v5 is not an option at the moment. Perhaps you remember that there were some threads in late 2021 between you, David and me about that migration process failing over and over again with different problems, when I first tried to switch to v5. Since then, the v4 installation worked fine until the recently expired TLS certificate started to be a showstopper.
I’m still not really convinced how a simple certificate can be a problem. The currently installed LetsEncrypt certificate is a standard RSA 4096 based file, essentially the same tech specs like the expired one, and it still doesn’t work and it still doesn’t state any comprehensible error message:
root@naruto:~# /opt/phantomjs/bin/phantomjs test.pjs
\n{
"contentType": null,
"headers": [],
"id": 1,
"redirectURL": null,
"stage": "end",
"status": null,
"statusText": null,
"time": "2023-09-01T09:22:56.827Z",
"url": "https://naruto.domain.tld/view/bxhafwuec0ofyokc031fucvxxk9v4jqq?phantomjs=true&phantomjs_secret=smbkalqnc0cu3jrbipzgjvihaovnmzkf",
"console": []
}root@naruto:~#
When changing the URL to http (after disabling the https requirement in the ninja settings) the command works. But I have no fudging clue why. Even with PhantomJS being discontinued for 7 years now, a simple crt file exchange causing these problems doesn’t make any sense imho.
However, to be able to send out our invoices, I’m going to remove everything related to https from the system and hope that it will work again, because if not, I’m not able to charge this month, which is worth about 120kEUR company income. That would be enough to render us bankrupt instantly.
I really really hope that I can get some help when trying another approach on migrating to v5 in the next few weeks (hopefully before the next monthly invoice run), but my first target must be getting the invoices out ASAP.
Thanks so far. I’ll start a new thread when I’m going to try the migration process again.
