Where can I find documentation for the ProductFilters class?
This class is mentioned in the Swagger Docs for Get Products:
“Query parameters can be added to performed more fine grained filtering of the products, these are handled by the ProductFilters class which defines the methods available”
You can use the method name ie status as the query parameter ?status= and then set your value you wish to query by. ?status=active
Note that we haven’t scoped out all of the possibilities, so if there is some specific you wish to include, we can add it to each entities flter class.
