Product Dropdown is lacking
I am coming from InvoicePlane. InvoiceNinja is great and I definitely wanna make the switch.
However The Product DropDown when adding to an invoice is lacking. I"m use to a more robust search feature, that allows me to see the ProductID/Name and “description”
Currently my Products Names are simple such as, Computer, Cable, Etc.
Then in the Description is where I put the detail of the Item. such as “Dell Optiplex 7090”
Any Options I have to change this? I couldn’t find anything on it.
The only way I can think of would be to prefix your productId’s with more info.
If you hover over the item in the search results you can see more details.
Also… feel free to create an issue on our GitHub project to have the feature improved.
