I did custom modification to App/Utils/Traits/MakesInvoiceValues.php to make position name with notes as one field separated by break-line. Code:
//in transformLineItems function, around 290 line
$desc = is_null(optional($item)->product_key) ? $item->item : $item->product_key;
$desc = $desc."\n".$this->processReservedKeywords($item->notes);
$data[$key][$table_type.'.item'] = $desc;
I know you’re working on it too, but I really needed it, so I did it myself. Code was working up to now. After last update apparently it stopped working correctly. Text is overlapping in this field, screen:
Any idea, what changed in code? By adding more break-lines \n notes part is moving right from it, but I want it below. How should I force it to make another line in this field?
After some update I back to this thread and used “fast mode” to get HTML by inspection and I found that for text in td and column-width it is not expanding in height, but overlapping text with every break-line. Earlier it was overlapping with and without column-width style set. Really weird, it seems it was problem with CSS styles (some weird combination), not break-line processing.
