Processing (lost connection?)
Version ie <v5.11.61>
Environment <Self Hosted, Dedicated VM>
primarily using Chrome as my interface into IN, i seem to only have a minute and i get disconnected? not really sure, when i save the action i was working on like a description in an invoices and push save, it goes to processing FOREVER it never ends, the change is not made, the PDF doesn’t update. If i do the same in the windows application it goes fine, and using it in edge is fine.
None, just has the little rectangle at the top saying processing…
I suggest creating an issue on GitHub
Ok, will do, thanks.
If it’s working in the Windows app it’s more likely a problem with the React app repo (linked above) than a problem with the backend (where you created the issue).
