I initially installed my v5 with Softaculous on my shared hosting setup, Unfortunately this seems to disable autoupdate as DISABLE_AUTO_UPDATE=true in the .env file
As part of getting the install to work ended up doing the following
- edit .env to change app location so not in /public
- edit .htaccess to match
- the directory that invoice.mydomain.co.uk pointed to so the it pointed at the public subdirectory
- adjusted that auto configured cron so that it ran more than the once per day than Softaculous configured it.
Unfortunately having made these changes to install it safely Softaculous no longer recognises the install so I canāt use that do updates.
So to update from 5.1.61 to 5.2.14 I realised I need to do it manually as per instructions Free Source Available Invoicing, Expenses & Time-Tracking | Invoice Ninja so Iāve downloaded the āsource codeā version (tar.gz) copied files in over the top of the existing install (checked the .htaccess doesnāt have the public redirect) and all I get is a 500 server error. [And yes I did backup the database and the previous install first]
This is the last entry in laravel.log - any ideas what is going wrong?
[2021-07-22 19:15:02] production.ERROR: Unresolvable dependency resolving [Parameter #0 [ array $options ]] in class App\Utils\CssInlinerPlugin {āexceptionā:"[object] (Illuminate\Contracts\Container\BindingResolutionException(code: 0): Unresolvable d
ependency resolving [Parameter #0 [ array $options ]] in class App\Utils\CssInlinerPlugin at /invoice/vendor/laravel/framework/src/Illuminate/Container/Container.php:1064)
#0 /invoice/vendor/laravel/framework/src/Illuminate/Container/Container.php(971): Illuminate\Container\Container->unresolvablePrimitive(Object(ReflectionParameter))
#1 /invoice/vendor/laravel/framework/src/Illuminate/Container/Container.php(906): Illuminate\Container\Container->resolvePrimitive(Object(ReflectionParameter))
#2 /invoice/vendor/laravel/framework/src/Illuminate/Container/Container.php(868): Illuminate\Container\Container->resolveDependencies(Array)
#3 /invoice/vendor/laravel/framework/src/Illuminate/Container/Container.php(714): Illuminate\Container\Container->build(āApp\\Utils\\CssInā¦ā)
#4 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(841): Illuminate\Container\Container->resolve(āApp\\Utils\\CssInā¦ā, Array, true)
#5 /invoice/vendor/laravel/framework/src/Illuminate/Container/Container.php(652): Illuminate\Foundation\Application->resolve(āApp\\Utils\\CssInā¦ā, Array)
#6 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(826): Illuminate\Container\Container->make(āApp\\Utils\\CssInā¦ā, Array)
#7 /invoice/app/Providers/MailServiceProvider.php(31): Illuminate\Foundation\Application->make(āApp\\Utils\\CssInā¦ā)
#8 /invoice/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Providers\MailServiceProvider->boot()
#9 /invoice/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#10 /invoice/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#11 /invoice/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#12 /invoice/vendor/laravel/framework/src/Illuminate/Container/Container.php(611): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#13 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(914): Illuminate\Container\Container->call(Array)
#14 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(895): Illuminate\Foundation\Application->bootProvider(Object(App\Providers\MailServiceProvider))
#15 [internal function]: Illuminate\Foundation\Application->Illuminate\Foundation\{closure}(Object(App\Providers\MailServiceProvider), 38)
#16 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(896): array_walk(Array, Object(Closure))
#17 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\Application->boot()
#18 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(237): Illuminate\Foundation\Bootstrap\BootProviders->bootstrap(Object(Illuminate\Foundation\Application))
#19 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(310): Illuminate\Foundation\Application->bootstrapWith(Array)
#20 /invoice/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(127): Illuminate\Foundation\Console\Kernel->bootstrap()
#21 /invoice/artisan(37): Illuminate\Foundation\Console\Kernel->handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#22 {main}
Iāve tried reverting back to the 5.1.61 version and editing .env to change the DISABLE_AUTO_UPDATE=false, but I canāt see where/how to then trigger the autoupdate from the UI.
Any suggestions please.
Ian
