Hi Hillel
We use 3 decimals “everywhere” and was able to edit the invoice amount in the blade and in PDF but the amount in the database is not as we look for.
Where can I find the “save invoice” precision settings please ?
Best regards
Hi Hillel
Best regards
Sorry, this would be complicated to change. There isn’t a single place in the code to point you to.
Would it be possible to just have a hint on the 1st place to check.
Thanks in advance for your support.
Sorry, you’d need to hire a developer to help.
https://github.com/invoiceninja/invoiceninja#third-party-developers
Thanks for your help
1st developer website not working
2nd is about 750 $ for invoice design
Maybe try hiring a developer on upwork?
Thanks Hillel, I am a devoloper and needed a single point to start, an advice, a hint and I’ll follow
Most of the “save invoice” code is in app/Ninja/Repositories/InvoiceRepository.php
Thanks ! That’s what I am talking about !!!
