f32b
October 4, 2018, 6:45am
1
Hi all,
I am using Self Hosted Invoice Ninja v4.5.5 .
I’ve issued an invoice to a client which is doing partial payments, actually we’ve agreed on installments and now after I’ve added 2 payments which he made, the due balance is showing less than it should.
The calculation
Subtotal : 2019.04€ - 201.90€ Discount = 1817.14€ + 18% VAT (327.09€) = 2144.23€ TOTAL
The installments that we’ve agreed are: 1st payment 40%, 2nd payment 40% and 3rd payment 20%
They’ve done 2 payments as below :
1st payment: 857.69€
2nd payment: 857.69€
Now, the balance due should’ve stated 428.85€, but instead it shows 101.76€ ??
Why is it calculating the VAT incorrectly/re-calculating it based on payments ?
Thanks in advance
October 4, 2018, 6:48am
I’m not sure, can you reproduce the problem with a test invoice?
f32b
October 4, 2018, 7:05am
3
Yes,
I’ve made a test invoice and again the same thing.
What’s more interesting is that now even the taxes are being calculated wrong. See .
And taxes arent being calculated on total!
October 4, 2018, 7:07am
4
That looks like ‘include taxes in cost’ has been enabled in the tax settings.
Can you check that this SQL query returns 0
select inclusive_taxes from accounts;
October 4, 2018, 7:14am
6
Is it possible this feature was enabled in the settings?
Do you have earlier PDFs you can check?
f32b
October 4, 2018, 7:27am
7
No, its not even in settings.
Yes, I’ve double checked from earlier invoices and everything is fine, except now.
The tax is being excluded from the total amount.
October 4, 2018, 7:28am
8
I’d suggest trying to change the value manually in the database.
Did you recently upgrade, if you have a backup from before it’d be useful to compare.
f32b
October 4, 2018, 7:32am
9
I am trying to restore to an earlier version but apparently the only version I have is 4.5.4, from which I think the problems started!
But, why aren’t taxes being calculated in total ? Do you have any idea ? Even in new invoices!
P.s They are also being calculated wrong ?
October 4, 2018, 7:37am
10
Because inclusive taxes are enabled
f32b
October 4, 2018, 8:11am
11
Are you proposing to edit the inclusive taxes manually on database?
