Problem with saving invoice on self-hosted server since latest upgrade
This issue strated after updating to latest version 3.1.2 i am receiving the following error when trying to save invoice with or without attachment.
error
LOG:
[00:26:27] LOG.error: exception ‘PDOException’ with message ‘SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘custom_value1’ in ‘field list’’ in /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php:478
Stack trace:
#0 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(478): PDO->prepare(‘update product...') #1 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database\{closure}(Object(Illuminate\Database\MySqlConnection), 'update product…’, Array)
#2 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback(‘update product...', Array, Object(Closure)) #3 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(483): Illuminate\Database\Connection->run('update product…’, Array, Object(Closure))
#4 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(426): Illuminate\Database\Connection->affectingStatement(‘update product...', Array) #5 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2124): Illuminate\Database\Connection->update('update product…’, Array)
#6 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(532): Illuminate\Database\Query\Builder->update(Array)
#7 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1562): Illuminate\Database\Eloquent\Builder->update(Array)
#8 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1481): Illuminate\Database\Eloquent\Model->performUpdate(Object(Illuminate\Database\Eloquent\Builder), Array)
#9 /var/www/ninja/app/Ninja/Repositories/InvoiceRepository.php(637): Illuminate\Database\Eloquent\Model->save()
#10 /var/www/ninja/app/Services/InvoiceService.php(84): App\Ninja\Repositories\InvoiceRepository->save(Array, Object(App\Models\Invoice))
#11 /var/www/ninja/app/Http/Controllers/InvoiceController.php(366): App\Services\InvoiceService->save(Array, Object(App\Models\Invoice))
#12 [internal function]: App\Http\Controllers\InvoiceController->update(Object(App\Http\Requests\UpdateInvoiceRequest), ‘23’)
#13 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(80): call_user_func_array(Array, Array)
#14 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(146): Illuminate\Routing\Controller->callAction(‘update’, Array)
#15 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(94): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\InvoiceController), Object(Illuminate\Routing\Route), ‘update’)
#16 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#17 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#18 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#19 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#20 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(96): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#21 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(54): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\InvoiceController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), ‘update’)
#22 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(174): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), ‘App\Http\Contro…’, ‘update’)
#23 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(140): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request))
#24 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(724): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request))
#25 [internal function]: Illuminate\Routing\Router->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#26 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#27 /var/www/ninja/app/Http/Middleware/Authenticate.php(101): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#28 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), ‘user’)
#29 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#30 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#31 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#32 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#33 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#34 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(726): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#35 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(699): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#36 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(675): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#37 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(246): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#38 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http{closure}(Object(Illuminate\Http\Request))
#39 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#40 /var/www/ninja/vendor/barryvdh/laravel-debugbar/src/Middleware/Debugbar.php(51): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#41 [internal function]: Barryvdh\Debugbar\Middleware\Debugbar->handle(Object(Illuminate\Http\Request), Object(Closure))
#42 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#43 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#44 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#45 /var/www/ninja/app/Http/Middleware/StartupCheck.php(201): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#46 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure))
#47 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#48 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#49 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#50 /var/www/ninja/app/Http/Middleware/QueryLogging.php(32): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#51 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))
#52 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#53 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#54 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#55 /var/www/ninja/app/Http/Middleware/DuplicateSubmissionCheck.php(39): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#56 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure))
#57 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#59 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#60 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(64): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#61 /var/www/ninja/app/Http/Middleware/VerifyCsrfToken.php(44): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#62 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#63 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#64 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#65 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#66 /var/www/ninja/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#67 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#68 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#69 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#70 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#71 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#72 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#73 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#74 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#75 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#76 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#77 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#78 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#79 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#80 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#81 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(59): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#82 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#83 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#84 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#85 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#86 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(44): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#87 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure))
#88 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#89 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#90 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#91 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#92 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#93 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(132): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#94 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(99): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#95 /var/www/ninja/public/index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#96 {main}
Next exception ‘Illuminate\Database\QueryException’ with message ‘SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘custom_value1’ in ‘field list’ (SQL: update products set updated_at = 2017-03-15 00:26:27, custom_value1 = , custom_value2 = where id = 45)’ in /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php:729
Stack trace:
#0 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback(‘update product...', Array, Object(Closure)) #1 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(483): Illuminate\Database\Connection->run('update product…’, Array, Object(Closure))
#2 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(426): Illuminate\Database\Connection->affectingStatement(‘update product...', Array) #3 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2124): Illuminate\Database\Connection->update('update product…’, Array)
#4 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(532): Illuminate\Database\Query\Builder->update(Array)
#5 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1562): Illuminate\Database\Eloquent\Builder->update(Array)
#6 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1481): Illuminate\Database\Eloquent\Model->performUpdate(Object(Illuminate\Database\Eloquent\Builder), Array)
#7 /var/www/ninja/app/Ninja/Repositories/InvoiceRepository.php(637): Illuminate\Database\Eloquent\Model->save()
#8 /var/www/ninja/app/Services/InvoiceService.php(84): App\Ninja\Repositories\InvoiceRepository->save(Array, Object(App\Models\Invoice))
#9 /var/www/ninja/app/Http/Controllers/InvoiceController.php(366): App\Services\InvoiceService->save(Array, Object(App\Models\Invoice))
#10 [internal function]: App\Http\Controllers\InvoiceController->update(Object(App\Http\Requests\UpdateInvoiceRequest), ‘23’)
#11 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(80): call_user_func_array(Array, Array)
#12 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(146): Illuminate\Routing\Controller->callAction(‘update’, Array)
#13 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(94): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\InvoiceController), Object(Illuminate\Routing\Route), ‘update’)
#14 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#15 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#16 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#17 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#18 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(96): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#19 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(54): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\InvoiceController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), ‘update’)
#20 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(174): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), ‘App\Http\Contro…’, ‘update’)
#21 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(140): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request))
#22 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(724): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request))
#23 [internal function]: Illuminate\Routing\Router->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#24 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#25 /var/www/ninja/app/Http/Middleware/Authenticate.php(101): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#26 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), ‘user’)
#27 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#28 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#29 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#30 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#31 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#32 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(726): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#33 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(699): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#34 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(675): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#35 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(246): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#36 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http{closure}(Object(Illuminate\Http\Request))
#37 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#38 /var/www/ninja/vendor/barryvdh/laravel-debugbar/src/Middleware/Debugbar.php(51): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#39 [internal function]: Barryvdh\Debugbar\Middleware\Debugbar->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#41 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#42 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#43 /var/www/ninja/app/Http/Middleware/StartupCheck.php(201): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#44 [internal function]: App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure))
#45 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#46 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#47 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#48 /var/www/ninja/app/Http/Middleware/QueryLogging.php(32): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#49 [internal function]: App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))
#50 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#51 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#52 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#53 /var/www/ninja/app/Http/Middleware/DuplicateSubmissionCheck.php(39): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#54 [internal function]: App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure))
#55 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#56 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#57 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#58 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(64): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#59 /var/www/ninja/app/Http/Middleware/VerifyCsrfToken.php(44): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#60 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#61 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#62 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#63 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#64 /var/www/ninja/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#65 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#66 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#67 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#68 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#69 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#70 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#71 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#72 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#73 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#74 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#75 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#76 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#77 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#78 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#79 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(59): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#80 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#81 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#82 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#83 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#84 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(44): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#85 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure))
#86 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(136): call_user_func_array(Array, Array)
#87 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request))
#88 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#89 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request))
#90 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): call_user_func(Object(Closure), Object(Illuminate\Http\Request))
#91 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(132): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#92 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(99): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#93 /var/www/ninja/public/index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#94 {main}
Thanks for the error details!
Two questions:
  • Which version are you updating from
  • Do you see any errors when you load /update (or /public/update) in your browser
Now the latest version , solved after force git pull
Thanks for the update!
